ignition switch - NCRS Discussion Boards
ignition switch
  • Robert V.
    • July 31, 2000
    • 84
    ignition switch
    Trying to replace the ignition switch, Removed the key core, but cannot figure out how to get the old switch out? The manual calls for a J-7607 special tool that I cannot find in the manual? Can this tool be rented at a NAPA's - Checker, etc. Also need to replace the windshield washer switch?
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: ignition switch
    I don't know what year you are working on, but whatever you can turn the nut with should remove it.
    • Mike E.
      • February 28, 1975
      • 5138
      Re: ignition switch
      Mentioning the year you're working on would help us address your problems.
      • Robert V.
        • July 31, 2000
        • 84
        Re: ignition switch
        Sorry, 64 coupe.
          Re: ignition switch
          Bob -
          The chrome bezel just unscrews - you don't need the special tool; use a piece of rubber to pad the jaws of a pair of pliers and it will come right off.
          • Robert V.
            • July 31, 2000
            • 84
            Re: ignition switch
            Thanks, John, will that also work for the windshild wiper bezel?
              Re: ignition switch
              Yes, but you can also use the points on a pair of needlenose pliers on that one.
