C2 nylon headlight bearing lube?? - NCRS Discussion Boards
  • Scott Marzahl
    What would be the best lubrication if any, when replacing the old metal bearings with the plastic replacement bearings, a general all purpose grease?
    Scott
  • Donald O.
    • May 31, 1990
    • 1588
    Re: C2 nylon headlight bearing lube??
    I used litium based grease a few years ago. Should be good for another 30 years or so.
    Don
    • Scott Marzahl
      Thanks Don and for the referral for the Headlight motor rebuild too, they look awesome.
      • Rory Riedy
        C2 - Headlight Motor Rebuild
        Scott,
        Would you share who Don refered you to? It may help a bunch of us in the same boat.
        Triple R
        • Scott Marzahl
          Re: C2 - Headlight Motor Rebuild
          Hi Rory,
          I used Steve Hackel in Illinois (708) 687-4183 for my headlight and wiper motors.
