62 F.I. Hydro-Lock revisited..help..... - NCRS Discussion Boards
  • Jerry J.
    • November 1, 2000
    • 54
    My first msge. had a typo... It's a 61 not a 62..
    Put it up on the hoist, drained oil, took pan off. Then took oil filter canister off and to the parts washer. Looking inside, I saw what appeared to be a grey substance around the bottom, a Very small amount.. Could this be anti-freeze in oil ?? Never seen it at any filter changes. Now I'm suspecting a blown head gasket... Did a compression test on cylinders...
    All but one read a nice 170 lbs. The # 2 read 110 lbs. Now what ??
    What does that tell me and where do I go from here ??
    It's like looking for a needle in a small block....
    Thanks again for any info.......
    Jerry......
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 62 F.I. Hydro-Lock revisited..help.....
    Rotate the crankshaft so that #2 is in the down position and then see if the rod is still straight.
    • Clem Z.
      • January 1, 2006
      • 9427
      the grey stuff could be lead from the gasoline. the low compression on 1 cylinder could be caused because that piston is not coming to the top of the bore because the rod is bend.
      • Don H.
        • December 1, 1981
        • 1487
        I had hydro-lock bend two "pink" rods and break pistons on a 4000 mile replacement CE short block. I now use a solenoid in the fuel line. Don H.
