69 backing plates zinc or cad? - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Okay, I know that the TIM&JG states that they should be un-polished zinc. However I seem to remember a post some time ago stating that cad was more correct...and also that cad and zinc are hard to tell apart. The latest post I remember says that they were galvanized. They are the original backing plates with some pitting so I was thinking that silver cad would be the way to go seeing as the clear zinc would more easily show the pits. What are your thoughts on this?
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: 69 backing plates zinc or cad?
    Sir:
    I cannot tell you Zinc or Cadmium. Galvinizing is a hot dip in another metal for coating which produces the crystalline surface appearance. Plating is an electrical deposition of one molecule at a time.
    I have only examined a very few GM Corvette blueprints, much less than 1,000. Based upon this limited view, I noticed that many metal parts had a plating spec that said "Cadmium or Zinc". Apparently it was up to the manufacturer to decide.
    I have bad news for you, neither Zinc or Cadmium will hide pits.
    Geoffrey Coenen
