C2 Transmission - NCRS Discussion Boards
C2 Transmission
  • Michael S.
    • May 31, 2002
    • 91
    C2 Transmission
    I have a 327/350 '67 convertible. Noticed about one week ago a very whiny, whirring first gear. Today I opened it up a bit and when I shifted from second to third the whine/whir started for good, real loud. Motor ran fine, I even had all the gears. The noise was real loud though, in all gears, in neutral and at idle. I limped home about 3 miles, garaged it and now it won't start. All I get is a whir from the starter. I am thinking ring gear or flywheel gave up. Any suggestions ?
    • May 31, 1974
    • 8396
    Re: C2 Transmission
    pull starter and have a peek at the flywheel/ring gear. mike
    • Terry F.
      • September 30, 1992
      • 2061
      Re: C2 Transmission
      It sounds the the starter gear stayed engage or something? I would pull the starter also. Terry
      • Michael S.
        • May 31, 2002
        • 91
        Re: C2 Transmission
        Thanks, will do.
