66 BB water pump - NCRS Discussion Boards
66 BB water pump
  • Richard S.
    • November 1, 1994
    • 809
    66 BB water pump
    Are the thread sizes the same for both the heater hose fitting....and the by pass hose fitting in the water pump itself? My by pass hose fitting seems to have a smaller thread than the heater hose fitting....I broke a fitting and need to find another one but the good one I have from the heater hose hole won't thread into the by pass hole....is it because the thread size is smaller?? Thanks for the help.
  • John L.
    • 409
    Re: 66 BB water pump
    Rick -- I think the fitting you mention is pressed into the housing.
    • Richard S.
      • November 1, 1994
      • 809
      John,
      It is a threaded hole......in the water pump.....help.....
      • Stephen L.
        • May 31, 1984
        • 3158
        On a 67 BB (I assume they are the same) The thread size for the water bypass is the same as the thread size for the heater hose on the water pump; 3/4 inch NPT.
        The heater hose fitting that screws into the manifold is the same size threads but the internal diameter and hose diameter is smaller; 1/2 inch.
        You need an internal diameter of 5/8 inch for the bypass hose with 3/4 inch NPT threads. NAPA may have it.
        • Richard S.
          • November 1, 1994
          • 809
          Thanks Steve.....
          • John L.
            • 409
            Rick - The 66 BB water pump's bypass fitting is pressed in per the judging manual. It would appear that either you have a non 66 original pump, a 66 pump rebuilt with a threaded bypass hole, or a non GM pump. In either case -- good luck with it -- hope you get it running.
            • Richard S.
              • November 1, 1994
              • 809
              Thanks John......
              • Richard S.
                • November 1, 1994
                • 809
                Thanks for the help guys.......I found what I needed. The threads are the same size and that is 1/2 inch NPT.
                  • 43240
                  Rick-----
                  What's the casting number of this waterpump? It should be 3856284. This casting was used from 1965 through early 1969. I am not aware of any original 3856284 pump castings that used a threaded bypass fitting. There may have been some, but I'm not aware of it.
