ORIGINAL '66 UPPER "A ARM" ATTACHMENT - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Are the upper a arm shafts secured to the bolts that hold them to the frame with "tall nuts and lock washers" per the JM, as opposed to the large crimp nuts in '67?
  • Rob A.
    • December 1, 1991
    • 2126
    ADDENDUM
    Are the nuts and lock washers bare steel or plated?
      • 43240
      Re: ORIGINAL '66 UPPER "A ARM" ATTACHMENT
      Rob-----
      Yes, standard nuts with lockwashers were used for 1963-66.
      • Michael H.
        • January 29, 2008
        • 7477
        Not 100% sure about this but I seem to remember mid or late 66 switching to the crimp style nuts that were used in 67. Maybe someone that has an original late 66 can verify?
          • 43240
          Michael-----
          Yes, the nuts did change sometime in 1966. From what I can tell, it actually looks like it could have been fairly early 1966.
          • Michael H.
            • January 29, 2008
            • 7477
            Ok, thanks Joe. I thought so but wasn't sure. I know the HD nut/lock washer was used at least through November but couldn't remember when it changed to the prev. torque style.
            • Rob A.
              • December 1, 1991
              • 2126
              Mike,
              The lower a-arm shafts on my car are also attached in the rear with lock washers and nuts, like the upper a-arms. They appear to have never been removed. My car has a June(66) build date.
              • Michael H.
                • January 29, 2008
                • 7477
                Rob,
                If they look original, then they probably are. I'm not 100% certain that either the upper or lower nuts changed to the prev torque style, or when it happened if it did, but I seem to remember the uppers changing late in the year. Hopefully, others with later production 66 cars will help sort this out.
                • William C.
                  • May 31, 1975
                  • 6037
                  Were the crimp nuts not also associated with a coarse thread design for the pressed-in bolt from the frame, or did that change come later as a third iteration?
                  Bill Clupper #618
                    • 43240
                    Bill----
                    For later 1966 and 1967 Corvettes, the Stover-type lock nuts were used with the 7/16"-20 (NF) bolts. For 1968-82, the bolts changed to 7/16"-14 (NC) and similar Stover-type lock nuts were used.
                    • Gary B.
                      • February 1, 1997
                      • 7033
                      '66 UPPER "A ARM" nuts for late build date
                      Rob,
                      The nuts on my July 20, '66 build date car are indeed the "tall" nuts, about 7/16" thick. Not the prevailing torque nuts, just the regular style (but tall) with a lock washer as per the TIM&JG.
                      Gary
                      • Rob A.
                        • December 1, 1991
                        • 2126
                        Re: '66 UPPER "A ARM" nuts for late build date
                        Gary,
                        Do you happen to know if they were bare steel or plated? Thanks...
