67 master cylinder part number - NCRS Discussion Boards
  • Dennis N.
    Infrequent User
    • April 1, 2004
    • 17
    What is the correct part number for a non p/b master cylinder, please? Also, date code of D6 and Julian code of 314 indicates what? Should DC stamping be on the part or not? Thanks for responding.
  • Brian M.
    • February 1, 1997
    • 1838
    Re: 67 master cylinder part number
    Dennis, I believe your looking for P/N 5455509 Date codes are not judged. Are you getting these #'s off the machined area's of the inlet or bleeder area?
    • Dennis N.
      Infrequent User
      • April 1, 2004
      • 17
      Numbers are on the right side of the unit..not on the inlet area.
      • Joe R.
        • March 1, 2002
        • 1356
        Dennis:
        The *casting* number for the standard brake master cylinder in 1967 was 5455509, and is featured prominently on the side opposite the brake line outlets. The letters D6, also cast into the unit, indicate a mold number. I do not know what the 314 is that you refer to. Is it cast into the unit or stamped somewhere? And yes, the letters DC should be stamped on a machined area on the front of the unit, facing up.
        • Dennis N.
          Infrequent User
          • April 1, 2004
          • 17
          The seller didn't kow what the 314 was or meant either. I was hoping to find out here. But the part number and the DC stamping you confirm is very much appreciated,thaks to all responders.
          • William O.
            • April 30, 2001
            • 355
            I might be mistaken, but the 67' did not have date stamped..
