paint removal - NCRS Discussion Boards
paint removal
  • Joseph T.
    • April 30, 1976
    • 2074
    paint removal
    Any suggestions on the best method to remove one layer of repaint to expose the original factory paint underneath..on a 57?
    The factory paint looks perfectly preserved and just needs to be exposed, White w/blue stripes..underneath!
    Joe
  • Scott Marzahl
    Re: paint removal
    Joe,
    This sounds like a very time consuming job. The only way I can think off that you could accomplish this, would be to painstakingly wet sand off the top coat. Hopefully there isn't any body damage that you aren't aware off lurking underneath. If not, you could then buff the existing original paint out.
    • Joseph T.
      • April 30, 1976
      • 2074
      Re: paint removal
      Scott
      Unless I find a better solution..a total wet sand is probably what I will do. By the way..I flew on the 777... on trips to China when it first came out..it had the most comfortable seats. However I did like the upstair seating on the 747 better overall...and the 4 engines.
      • Scott Marzahl
        Who needs four engines...
        Yes, that 777 is an awesome airplane, I have made too many trips to the East myself
