c2 AM/FM radio removal - NCRS Discussion Boards
  • john pickens
    Well, I have the original radio free behind the console. But it sure does not want to rotate out. The auto is a 65 AC 350 roadster. Any tips to complete the
    removal successfully? Thanks.
  • William C.
    • May 31, 1975
    • 6037
    Re: c2 AM/FM radio removal
    do you have the lower heater outlet removed?
    Bill Clupper #618
    • Wayne M.
      • March 1, 1980
      • 6414
      Also helps to remove center metal console ...
      .... the following Delco instructions are more elaborate than neccessary (IMO).
      -- Remove both radio side panels
      -- (as Bill said) remove lower heat duct
      -- Remove radio support screw lower RH
      -- Remove knobs and hex nuts
      -- Remove glove box Disconnect speaker, antenna and power connections
      -- Carefully tilt radio top back. It may now be removed by carefully
      manipulating through the side
      -- Be sure to peak antenna trimmer after reinstallation, or radio performance may suffer.
      • Brian M.
        • February 1, 1997
        • 1839
        Re: Also helps to remove center metal console ...
        I have never removed the heater duct or glove box and can have a radio in or out in about 15 mins. on my 67 with A/C.
        • Ralph E.
          • February 1, 2002
          • 905
          Sometimes the console needs to be removed. On a '65 this should be easy work. On a '67 is is a PIA as the E-brake needs to be re-adjusted.
