C2 battery tray - NCRS Discussion Boards
C2 battery tray
  • john pickens
    C2 battery tray
    Cannot seem to find this simple info in archives, AIM or LI Corvette catalog
    in clear fashion: trying to change out battery tray on my 65 AC roadster, battery on drivers side. Where and how many screws to remove the tray? Thanks
  • Gary C.
    • March 1, 1998
    • 236
    Re: C2 battery tray
    John
    Would probably be found under the C60 section of your AIM.
    Condensed version: Disconnect battery, remove wheel and the inner fender panel. Remove battery and then tray. The tray is bolted to the frame rail.
    • Wayne M.
      • March 1, 1980
      • 6414
      6 bolts for C60/L78 (4 outboard frame; 2 inboard)
      You can't see the inboards from the sketch in the AIM. You will probably have to also remove the outboard RH splash shield, to get the rearmost outer bolts.
