1954 trunk lock - NCRS Discussion Boards
1954 trunk lock
  • Mike P.
    Infrequent User
    • July 31, 2002
    • 3
    1954 trunk lock
    Could anyone advise me how to open the trunk on a 54 when the key turns but it won't open. It made a noise like something come loose then quit working. How do you get to latch inside.
    Thanks, Mike
  • Mike P.
    Infrequent User
    • July 31, 2002
    • 3
    Re: 1954 trunk lock *NM*
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 1954 trunk lock
      No way that I can think of. But if it were me I would pray the key assy front bezel off , that would allow the inside assy to fall out , then using some thing long that would replace the key extension to un-locks it. As a last resort drill the key housing back out to reach the latch. The housing is the same as many early GM's.
      I think the key long flat extension spring may have fallen off.
      Then if you need another key housing I have one you can have.
      • Dave Suesz
