temperature sender for a 1963 - NCRS Discussion Boards
  • Joe C.
    • April 30, 2001
    • 126
    I have installed a new temperature sender in my 1963. But I cannot get it to work right. My gauge will not work , But when I ground the sender the gauge will respond. But when I take off the ground it will not work. These senders are supposed to be grounded on the block. I have not used any substance on the sender. Any one have any idea what is wrong here. It doesn't seem to be the temp gauge itself because as I wrote when I ground it myself the temp gauge will work.Thanks
  • Mark S. Lovejoy
    Re: temperature sender for a 1963
    Check the ground strap from engine to frame, I think yours is at the left motor mount. Sounds like you are missing the return path.
    • Randy S.
      • January 1, 2003
      • 586
      I have always assumed that since the strap is shown in U69 radio section it is only for radio interference, like the exhaust to frame straps. I am missing mine (1966) and my sender works. Of course there could be another return path to ground.
      Randy
      • Mark S. Lovejoy
        Randy, you are correct.
        The negative battery cable is connected to the engine with a starter motor attaching bolt. There is a black wire (ground) from the engine wiring harness connected at the same place, I'd start looking there. The symptoms point to a poor ground.
          • 43221
          Joe-----
          .....or, it could be something as simple as a defective sender. Did you try another one?
