@%#+!! WCFB!! - NCRS Discussion Boards
@%#+!! WCFB!!
  • Don Izzo
    @%#+!! WCFB!!
    Seventy two degrees outside, got out of work at 3:30 thought I'd take the 60 out for it's first run of the season, just to blow the winter dust off, you know? Well I finally broke down and bought one of those battery tender thingies so the motor starts turning on the first hit of the key...after a few moments and a lot of peddle pumping, the motor starts but the choke didn't set along with the high idle. Hmmmmm...changed out that stove spring and housing last year...oh well after two minutes I won't need it anyway. So off I go. Stop at the first light and the rpms fall throug the floor pans. Stall, Damn, off again and pull up in front of my daughters house and STALL, Damn. Now it's hard to restart. I'll bet that damn choke is closed. Yup! What the hell is going on here!
    Ok Guys, I'm fed up. Before I pull this sumbitch and install a Holly, I'll give it just one more try. Where can I go to get a good reference on the WCFB and it's choke. My Vette manual is sorely lacking on the carb. MY 56 Belaire service manual is just marginally better. HELP!
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: @%#+!! WCFB!!
    make sure the exhaust heat tube that passes thru the exhaust manifold is not burned thru and allowing exhaust gas into the choke housing,been there seen that
    • Mark B.
      • February 1, 2004
      • 138
      Re: @%#+!! WCFB!!
      Don,
      Try this link off Amazon.com....http://www.amazon.com/exec/obidos/tg...s=books&n=1000
      It is for a technical book on how to tune Carter Carburetors. Good luck.
      • Dave F.
        • December 1, 2003
        • 508
        Re: @%#+!! WCFB!!
        I'd be thrilled to swap a Holly for that Carter!!
        • Larry P.
          • June 30, 1999
          • 481
          Re: @%#+!! WCFB!!
          Before you give up, give it to Bob Kunz in St. Louis. I had no luck with anybody until I took it to him. Now it works fine. If somebody elsr doesn't give you his phone number, let me know, I have it at work and I'll be there tommorrow.
          LP
          • Larry P.
            • June 30, 1999
            • 481
            Bob Kunz
            His number is 845-2566
            • Chris S.
              • January 1, 2000
              • 1068
              Re: @%#+!! WCFB!!
              daytona auto
              Daytona Parts Co. A premier supplier of high quality carburetor repair kits and Ethanol resistant carburetor component parts for carburetors, from 1923 thru today
              ask for ron
              will resto the carb
              quick turn around
              bob is nice but very slow turn around
              not a very good communicator
              1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
              Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
              1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
              1957 Corvette - FI 3 sp - Black and Silver
              • Mike M.
                • September 30, 1999
                • 710
                Bob Is Great
                Bob did my carb and was great. Told me everything I needed and priced it out before he started work on it. Easy to work with. I found the turn around to be fine. Better then a lot of others. He runs your carb on a engine and makes sure it's working right. Put the carb on filled the bowls with gas on a brand new rebuild. It started perfect and all I had to do was turn the idle screw a little. High idle worked fine and the kick down. Would use his services anytime and highly recomend him. Mike
                • Robert Willis
                  Re: Bob Is Great
                  I'm amazed at all the troubles with WCFBs. I put kits in mine (early 57s) , set them up and haven't touched them in 3 years.
                  Bob Kunz, I have heard alot of good about him.
                  Bob.
                  • Jim K.
                    • September 30, 2003
                    • 64
                    Re: Bob Is Great
                    I had my WFCB restored at Chicago Corvette (Al was the restorer) and it was the best two or three hundred dollars I ever spent. I got it back installed it and one turn of the key and it started right up and has ever since.
