'65 396/425 Exhaust Manifold Choke Tube - NCRS Discussion Boards
  • Mark S. Lovejoy
    A few weeks ago I posted a question regarding the install of the choke tube inside the exhaust manifold, thanks to those who responded.
    The question now is; should the installed choke tube extend outside the manifold? If so how much?
    Or; should the tube ends be recessed into the manifold.
    Final Question; How should the two choke tubes from the carb connect to the manifold tube?
    Could someone with an original example provide a picture?
    Mark
  • Wayne M.
    • March 1, 1980
    • 6414
    Here's my observations
    The external tubes are currently installed on my 3856302 manifold, and I seem to recall (without removing them) that both the forward/upper and the rear/lower ends of the inside heat tube are recessed about 1/4" into the cast iron. Then, both the clean/cold air tube (from the tube on the carb inlet flange) and the hot air outlet tube from the forward exh. manif. to the carb choke stove, are interference-pressed into the exh. manif., to abut against the internal tube.
    There's an overall X-section of this manifold in Colvin's '65-69 Chevy book, but no details of the tube area, except that it would appear on section "AB-AB" of the GM drawing (which is not reproduced in Colvin's book).
    Sorry; no picture, but not sure that one would help.
