C-1 Heat Shields - NCRS Discussion Boards
C-1 Heat Shields
  • Bud Baker
    C-1 Heat Shields
    1956. Did they use the same chrome lower shield as the '57? I can not find anything on what the shields that cover the plugs look like. I know about the ones that are curved and go below the manifold. Got them. Also, what year used a bracket that went around the coil and the Distributer. Thanks much for your help. Bud #35441
  • Mark S.
    • July 31, 1983
    • 660
    Re: C-1 Heat Shields
    1956 and 1957 used the same shields to cover the plugs. 1956 used a bracket that went around the coil and distributor.
    • Roy B.
      • February 1, 1975
      • 7044
      Early 56 is totally different then any later 56.
