60 carpet install is to easy - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    The carpet from Al Knoch fit with NO cuts. The only place I had to trim was where the seat belts anchor on the inside, shifter and the high beam switch. If you're thinking about doing it, don't sweat it, it's one of the more simple things on the entire restore. If your not comfortable with cutting the hole for the high beam, remove the switch and set the carpet. Mark the carpet from the engine side and cut the hole like that. The spray glue worked great. Don't spray it until your sure your ready to put the carpet where it belongs.
    5 pieces go in, front center, rear center, middle center and then sides.
    Larry
  • Tom B.
    • March 1, 1978
    • 720
    Re: 60 carpet install is to easy
    Did you use any heat barrier?
    Tom
    • Larry P.
      • June 30, 1999
      • 481
      No *NM*
