60's first test drive A- - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    First time ever on the street. Drove it up and down and around the block.
    Only one problem, so far. I thought, Boy is this thing geared HIGH!
    I discovered 3rd gear is where 1st should be and 1st is where 3rd should be.
    I installed the linkage about 5 years ago. I just put it where it looked like it should fit. Can the rods be reversed where it would work like that?
    Larry
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 60's first test drive A-
    simply remove the shifter lever and rotate it 180 degrees. mikie
    • Mike M.
      • May 31, 1974
      • 8385
      PS: i hope you meant 1st and 2nd are reversed, not 1st and 3rd as your post states. mike
      • Anthony F.
        • December 1, 1985
        • 191
        Double check the location of your shift rods on the shifter to AIM. I believe that you have the 1st to 2nd switched with the 3rd to 4th.
        • Larry P.
          • June 30, 1999
          • 481
          If that's possible it makes sense because reverse is where it should be.
          I hope this is my worst problem.
          Larry
          • Dennis A.
            • April 30, 1999
            • 1010
            What a day just to drive, congratulations *NM*
            • Ted S.
              • January 1, 1998
              • 747
              Larry, does the 1/2 and the 3/4 shift rods cross each other? If not they shoud. Take a look at this pic it may help.
              • Larry P.
                • June 30, 1999
                • 481
                Thanks Ted, That will help. *NM*
