70-72 Black-out - NCRS Discussion Boards
70-72 Black-out
  • lyndon sharpton
    70-72 Black-out
    black out on 70-72 cars. what would be a good paint to use?
  • Dick W.
    • 10483
    Re: 70-72 Black-out
    I have used PPG's DDL-9300 lacquer with good results. I believe that you can shoot it right out of the can with no thinning
    Dick Whittington
    • lyndon sharpton
      Re: 70-72 Black-out
      was the paint on the mufflers the same as under the hood an grill? anyone know of a good spray can of paint that would be close? how much gloss is on the muufflers as opposed to the grill area an under hood?
        Re: 70-72 Black-out
        Archival GM photos at Body Drop show the early C3 muffler blackout to be quite glossy; it wasn't lacquer like the underhood blackout - it was cheap asphaltic-based "chassis black" paint.
        • lyndon sharpton
          Re: 70-72 Black-out
          thanks could you get the look with a high heat paint are would that be to dull? are do they makle a high heat gloss black paint? anyone know?
            • 11643
            Re: 70-72 Black-out
            I just used Krylon Semi-Gloss and it worked great. The mufflers do not get hot enough to warrant high heat paint. The mufflers on my 72 look like they were done just yesterday, and I've put a couple thousand miles on it.
            FYI, when I first bought my 71 I painted the mufflers Rustoleum silver with a brush (in 1994). When I took off that exhaust 2 years ago and replaced it, the mufflers had just started to look poor. So, don't worry about high heat.
            Patrick
