C2 valve to piston clearance - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    327, 462 heads, domed SHP pistons, LT1 cam. I measured valve clearance at 250 thousandths. Is that an acceptable number. I've seen reference to minimum clearances in the 80 to 100 range, but no reserence to max clearance.
    Steve
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C2 valve to piston clearance
    measure the P to V clearance at 10 degrees BTC exhaust and 10 degrees ATC for the intake. the easy way is to use a light valve spring,set the running clearance, set the engine to the above settings and push down on the retainer and use a feller gauge between the valve stem tip and the rocker arm to check the clearance.
      • 15692
      I recall the mininum recommended for a racing engine is 50 thou. When you use a OE type domed piston with an OE cam, it's not something you normally need to worry about, but it can be an issue with a very high compression piston and a long duration, high lift racing cam.
      • Mark #28455
        there is no maximum clearance *NM*
