Picture of St.Louis Plant 1964 - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    The attached picture of the St.Louis Corvette Plant was taken in 1964 at the completion of the expansion.
    This is my first attempt at posting a picture..so lets see what happens!
    Joe
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Picture of St.Louis Plant 1964
    Excellent picture! Thanks Joe.
    • Mike L.
      • January 1, 1986
      • 312
      Nice job!!!
      • Rick S.
        • January 1, 2003
        • 1203
        Joe,
        Do you know what is hanging above each door? Great photo!!!
        • Joseph T.
          • April 30, 1976
          • 2074
          I will have to check..they may be unfinished canopies
          • Tom D.
            • September 30, 1981
            • 2134
            Joe: Your photo will show better if you reduce the pixel dimensions.
            I checked your photo above, and it's 2201x1495 pixels. This makes it a bit large for most web pages, or for e-mailing.
            It's very common for people to use their first images "straight from the camera". Instead, I recommend you reduce the image size, save it under another name and then post them. The width I would use is 500 to 600 range.
            I will take the photo you sent me, post it on one of my sites, and then post it here, to show you what I mean.
            T. Dingman
            4889
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Tom D.
              • 2134
              Michigan Chapter
              Tom Dingman
              • Larry P.
                • June 30, 1999
                • 481
                Tom,
                In most cases you are correct, in this case I like Joes picture. It is amazing clarity for a 40 year old picture from what? I can see more details in the larger picture.
                • Tom D.
                  • 2134
                  Larry - I have to agree, since the Corvettes are all over to one end. I assume the orig. was a 35 MM SLR, and it seemed to scan in very well.
                  Credit Joe for that.
                  Tom
                  Michigan Chapter
                  Tom Dingman
                  • Steve Antonucci
                    If he used a scanner, I'd like to know which model it was.
                    Steve
                    • Mike M.
                      Director Region V
                      • August 31, 1994
                      • 1463
                      This one camr through. Thanks, Tom, Kewl shot.
                      H. a. N. D.
                      • Stephen W.
                        • March 1, 2002
                        • 301
                        So with the picture dated 4/14/64 and my build date of 4/9/64 did my car just roll out of those doors the week before?
                        Great picture... facinating history
                          Ah, memories - that's where Final Repair, Water Test, and the Visualiner were relocated (water test was VERY busy during the '68 launch)
                          • Joseph T.
                            • April 30, 1976
                            • 2074
                            Scanned the original picture with an HP officejet G85.
                            The original picture was taken by a professional photographer contracted to take the progress photo's of the 1963/1964 expansion of the St.Louis Plant.
                            • Anthony F.
                              • December 1, 1985
                              • 191
