C-1 Flywheel Timing Marks - NCRS Discussion Boards
+ More Options
Posts
  • Robert S.
    • July 31, 2004
    • 377
    According to the service manual the steel ball is suppose to be the correct timing mark when aligned with the pointer. But I've noticed two
    other marks on my 54 6 cyl flywheel. One is an upside down triangle and the other is the number 2 to either side of the steel ball.
    Does anyone know the significance of these marks? The triangle is before the steel ball (as the flywheel rotates) so could it be this is an advanced setting and the "2" is after the steel ball, so could it indicate 2 degrees ATDC setting.!?
    As always, thank's in advance for sharing your wealth of knowledge.
    Bob
    Bob
  • Chris S.
    • January 1, 2000
    • 1068
    Re: C-1 Flywheel Timing Marks
    On my flywheel is just the triangle. and the letters BC
    I need to know also.
    As I will put putting in the dist next weekend.
    I dont see a steel ball on mine.
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
