Converting non-SMOG to SMOG manifolds - NCRS Discussion Boards
  • Steve Antonucci
    Re: Converting non-SMOG to SMOG manifolds
    John,
    Is this tap a standard? Possibly available from Snap-On or similar outlets?
    Do you have any experience with the actual design of the port itself?
    Steve
    • Cary Lewis
      Steve I just solved the same problem on my '74 BB. I'm going back with A.I.R. and my right side exhaust manifold had been replaced with a non A.I.R. manifold. I considered the drill and tap method but found an exhaust expert in St. Petersburg, Fl. that has thousands of manifolds, he may be able to help, call him at 727-525-1558, his name is Neal Bridges. By the way, I'm told that the date on the back of those manifolds can't be seen even with a mirror. Good luck!
      Cary Lewis
      • Steve Antonucci
        Thanks Cary !
        Unfortunately, I'm one of those people to whom the dates do matter.
        I will contact him, but I still would like to consider surgery on my
        existing manifolds.
        Steve
        • Steve Antonucci
          This is a follow-up question for the research oriented members amongst us.
          Can anyone suggest where I can locate a GM drawing showing the SMOG port
          details ( depths, angles, tap, etc. )? I looked in Colvin's books. It shows
          exhaust manifold 3872741 ( 66-68 small block ) and details the SMOG ports
          accordingly. See page 210 ( figure 10-28 ) in the 65-69 "By The Numbers".
          I don't know if small & big block ports are the same though. I could not find
          any dimensional references for big block exhaust manifolds in either of Colvins
          books.
          By the way, that drawing does indeed call out a 1/4 - 18 NPSF thread and
          not the 1/2 - 20 "straight pipe thread" mentioned earlier.
          Any ideas?
          Steve
            • 43221
            Re: Tubes
            Paul-----
            These particular tubes are the SERVICE replacement for the 1979-ONLY application. The earlier tubes do not have the unusual end configuration.
            • Paul L.
              • November 1, 2002
              • 1414
              Re: Tubes
              Thanks Joe,
              I was trying to helpful with the possibility that I was perhaps wrong. I appreciate being being corrected before I led anyone off in a misleading direction.
                Steve -
                My previous reference to 1/2"-20 was only to mention that functionally, a 1/2"-20 bolt will thread perfectly into a 1/2"-deep 1/4"-18 NPSF-threaded hole; it's only a coincidence that it works that way.
                • Steve Antonucci
                  Sorry John !
                  Didn't mean to shoot the messenger.
                  Steve
