70 lower bellh. cover - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    Want to replace the cover on my 70 L-46. 4sp. The one on the car appears to be what I have found still available (GM 3843943). Has a round starter hole.
    I have also seen part#354497. Has a "D shaped" starter hole. Application also for 70-72. Which is correct?
    • 43234
    Re: 70 lower bellh. cover
    Dennis-----
    The GM #3843943 is the correct cover for your application. This is the cover used with bellhousings designed for 14", 168 tooth flywheels.
    The GM #354497 is a cover designed for use with bellhousings designed for use with 12-3/4", 153 tooth flywheels. The 354497 is NOT the cover originally used for 63-72 applications with 12-3/4" flywheel bellhousings. That part was GM #3788422 which the 354497 replaced.
    By the way, current versions of the 3843943 (and, those available for about the last 25 years) are not exactly the same as the originally-installed and early SERVICE version of the same part. What's the difference? The current version has 2 small "tabs" at the center radius which are designed to "clip" onto the rear oil pan seal lip on the oil pan. This prevents the cover from road debris/water puddle-induced inward deflection of the cover and subsequent contact with the crankshaft flange.
    The ONLY one to use is the CURRENT version WITH the tabs. Absolutely. Positively. Period.
    • Dennis D.
      • March 1, 2000
      • 1071
      Joe
      Is this the new version?
        • 43234
        Dennis----
        Yes, it is. Note the small, offset "tabs" at the "4 o'clock" and "8 o'clock" positions on the center radius.
        • Dennis D.
          • March 1, 2000
          • 1071
          This is exactly like the old one on my 70.(Been there since I bought it in 73) If this is the new style, could mine have been replaced prior to 1973 with this newer version?
            • 43234
            Dennis----
            Yes, I think that's possible. I don't think that the original versions of the cover had the "tabs"-----the original cover on my 1969 did not, that's for sure. Just when they were added, I don't know. Possibly, it could have happened for the 1970 model year, but I don't think it happened that early.
            • Del S.
              • March 1, 1991
              • 83
              Joe, should this cover (3843943) fit the .....403 bellhousing?
                • 43234
                Del-----
                No, the GM #3843943 will not fit a GM #3858403 bellhousing. That bellhousing is designed for use with a 12-3/4" flywheel. The cover currently available to fit that application is GM #354497.
                By the way, the only 1970 Corvettes that ever used the '403' bellhousing were the 25 ZR-1s manufactured. No other 1970 Corvette originally used that bellhousing.
