Correct head marking for drain plug on a C2 6Qt. - NCRS Discussion Boards
  • Irby G.
    • November 1, 2001
    • 267
    I've got an early '63 340hp. Just curious if anyone knows off the top of your head if the marking is an 'A' w/circle around it or a 'F-C'? Thanks
    • 43221
    Re: Correct head marking for drain plug on a C2 6Q
    Irby-----
    The "A" within a circle was ONE of the headmarkings used for the drain plug on C2 Corvettes regadless of installed pan. I'm not usre about the "F-C".
    • Irby G.
      • November 1, 2001
      • 267
      Thanks Joe. I'll search for the 'A' unless someone knows for sure about the 'F-C'.
        Can't speak about F-C...
        but I've removed 'L' and 'TR' marked pan plugs from original Chevy in addition to the Circle-A which seems to be the most common. I suspect there were multiple vendors qualified to serve this application with the use of secondary suppliers a function of 'when built,' who had the best price at the time, freight-in cost, and availability. I wouldn't rule out the F-C fastener as being 'correct' if it has the same general dimensions as the others....
        • Irby G.
          • November 1, 2001
          • 267
          Thanks Jack...
          I'll add L & TR to the list of markings to look for. Thw F-C plus I was looking at is the same dimensions as the others, I just wasn't sure if I should go after it. Aloha
