62 Wiring - white tie wraps - NCRS Discussion Boards
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    JG says "white plastic tie straps .. one above each horn, to secure wire bundle." Since the wires appear adequately held by the 3 metal clips in that general area I am not sure just where to put the white tie straps.
    Any thoughts would be appreciated.
    John
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: 62 Wiring - white tie wraps
    John...
    Two Tie Straps are used on the front Horn/headlight wire harness. They are installed at the point were the outer connectors are attached, holding the wires to the main harness, that lead to the headlamps/parking lamps. The AIM shows them very clear.
