WCFB fuel pressures - NCRS Discussion Boards
WCFB fuel pressures
  • David B.
    • July 31, 2004
    • 330
    WCFB fuel pressures
    I am considering mounting my 2X4 WCFB setup (2626S/2627S) on the 350 that I run in my '57. (The 283 block is put away for safekeeping.) I have seen info that the WCFB's should not have a fuel pressure exceeding about 4.5 psi to operate properly. My question is (1) anyone have experience running this setup with a stock 70's era fuel pump? (2) anyone know if I can mount a 57 fuel pump on the 350 to achieve a proper fuel pressure? (3) any other things to watch for?
    David B.
    Dave, 1969 427, 1957
    Previous: 1968 427, 1973 454
  • James F.
    • December 1, 1985
    • 596
    Re: WCFB fuel pressures-David
    David, IMO volume is as imprtant aspressure, maybe more so. My '56 2X4 engine. fuel pump can't supply over 3.7 pounds pressue, yet car does fine on the interstate @ 56oo RPM. Your 3/8" D fuel lines are larger than the '56's 5/16"D.That's in your favor. Try your system first, don't think you'll have anything to worry aoutwith a 70's era fuel pump meeting the specs as staten in the ST-12. Regards
    • David B.
      • July 31, 2004
      • 330
      Thank you Jim.
