I just removed my 5 wheels and threw away the tires. Lucky for me I again have 3 different styles!!
One is welded with 3 nubs on the center raised ring for the small hub cap and 4 nubs in the outer rim.
Three riveted but has the same nubs as above and virtually identical rim and disc. The open area between the rim and disc is the same except more rounded at the ends.
One riveted with no nubs anywhere, completely different disc with 5 threaded holes.
Does anyone have a picture of a correct wheel? Does my welded one sound correct? Where can I get correct wheels? ( I will take a look in the Driveline) Looked at the archives but a pictue would help.
Thanks, Chris
Thanks, Chris
