C2/Carter 3461S Replacement Suggestions - NCRS Discussion Boards
  • Les Jacobs
    My carb apparently has an off idle (up to 1600rpm) problem, and I plan to temporairly swap it out with a "new" carb to confirm. Since it is only for a test, I am not too concerned with appearance, but I would like to minimidze the hook up problems. Would the Edlebrock Performer 1405,1406 be approprite and are there better choices? Thanks Les
  • G B.
    • December 1, 1974
    • 1407
    Unlikely
    I don't know of another carb with an old AFB bolt / venturi pattern. The modern Edelbrock and Carter Performance carbs use a Holley pattern baseplate.
    • G B.
      • December 1, 1974
      • 1407
      Correction, I think.
      If a Carter 3461 is a WCFB, then my answer doesn't make much sense.
      I probably should have said "WCFB" in my first response instead of "AFB". Even so, I still don't know of any modern carb that will fit with the same bore spacing and bolt pattern. Sorry.
      • Les Jacobs
        Re: Correction, I think.
        Jerry You were right the first time (about the AFB part). But based on my measurements the 3461S AFB bolt pattern is 4 1/4 between the front inner holes, by 5 5/8 deep. I believe this is the same spacing as the Edelbrock 1405, so it appears like it "should" fit. But.. the bore spacing is something I hadn't considered before. Thanks Les
