C3 Muncie Shifter Lever Part #? - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    At the bottom side of the lever there is an embossed part number 3621640.The lever measures 11 3/8" long from top of the thread to the bottom.
    Is this a 68-76 style or later?
    Greg
    • 43221
    Re: C3 Muncie Shifter Lever Part #?
    Greg-----
    I believe that you're reading the number incorrectly. I think that it's actually 3921640. This is the forging number for the 68-76 lever, GM PART #3921638.
    In any event, I'm unsure of the "parameters" of the measurement you've provided. I can tell you this, though: the length of the shaft section of the 68-76 lever is 6-15/16" from the base of the round shaft to the top of the shaft (i.e. top of the threads). The length of the 77-81 shaft is 7-16/16". The 77-81 shaft may carry the forging number 378186 or 378187.
    The length of the "round shaft" portion of the shifter lever is the only difference between the 68-76 and 77-81 assemblies.
