C1 Powerglide Relay - NCRS Discussion Boards
C1 Powerglide Relay
  • Roy B.
    • February 1, 1975
    • 7044
    C1 Powerglide Relay
    I saw some bids for the #904 relay on e-bay up to $400.00 and again thought I would pass on info that using a car over drive relay works the same and looks the same.
    On the original the number cant be seen any way , the car terminal (one) is pointed wrong but for about $40.00 you have it, or have as a spare for emergency use.
    You could probably work on it to move the terminal to look original.
    But all in all here it is.
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C1 Powerglide Relay
    i have some 904's and on some, the # is stamped on the exposed face, making it a judgable item. mike
    • Debra P.
      • September 30, 2004
      • 147
      If it on the firewall near the trans dipstick, mine has 904 on the silver bracket inbetween the 2 philps head screws below the black Delco Remy made in USA cover. I am not a mechanic but I hope this helps.
      Deb 42699
      • Mike M.
        • May 31, 1974
        • 8389
        deb: your relay is an example of the 904 # being exposed. some are exposed, others not. mike
        • Roy B.
          • February 1, 1975
          • 7044
          Many Fork lifts ( carpet and what ever) used a relay looking just like a Corvette and was sold to Corvette owners years ago. But on the back side a piece of metal strap was soldered to two terminals to make it work for the Corvette. A Four speed back up light switch was also sold to owners of PG as a replacement safety neutral switch which you can still use if missing the original.
