C2 Expansion tank - NCRS Discussion Boards
C2 Expansion tank
  • Michael S.
    • May 31, 2002
    • 91
    C2 Expansion tank
    How do I remove the cap on my expansion tank ? I turn it counterclockwise until it appears to hit 2 stops/tabs on the neck. I can't seem to jimmy it off there nor have I been successful in depressing the cap further to clear the tabs and further rotate counterclockwise- unless I need to try harder.
    Looks like spring in Connecticut today- I think I am going for a ride !
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C2 Expansion tank
    Counterclockwise as shown on the cap is the correct direcction to remove the cap. It should turn to the tabs, and then be depressed to complete the removal. Your cap is probably stuck in such a manner as it cannot be fully depressed to clear the tabs. A little more grunt force to depress it is required. If you have an aftermarket cap there is the possibility that the tabs are slighly different and you may need a little more rotational force...
    Good luck.
