71 fan shroud - NCRS Discussion Boards
71 fan shroud
  • Ralph A.
    • May 31, 2002
    • 236
    71 fan shroud
    What is the correct part nunber for the fan shroud. Car is a late 71 with A/C. Currently has part 3956109 and is missing the bottom section.
    Is this the correct part for an A/C Auto car?
    If so can the bottom extension be purchase by itself.
    Does the bottom have a part number?
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    • 11643
    Re: 71 fan shroud
    Ralph,
    The bottom section can be purchased by itself. I bought one a while back for my 71. Of note, someone had painted it black, so I used paint stripper and revealed the natural black fiberglass, which is how it should appear. Check with Doc Rebuild - he may have them, and I know he has the fasteners.
    I'm not able to check my 71 at the moment to confirm the number. I could on Sunday, however.
    Patrick
    • Dick W.
      • 10483
      Re: 71 fan shroud
      I believe that the extension part # was 331870, long discontinued. There are several vendors that are reproducing this piece. One is Jim Sermersheim's in Evansville, Indiana Phone 812-424-4701
      Dick Whittington
      • Ralph A.
        • May 31, 2002
        • 236
        Re: 71 fan shroud
        Thanks, the Doc had the part. Now I noticed the shroud number is Paragon's catalog is for a non a/c car 4 speed. May have to change it if the extension does not fit.
        Thanks All
        Ralph
        Ralph Adams
        NCRS: 38137 LA: 112
        Slidell, LA 70461
          • 43221
          Re: 71 fan shroud
          Jim-----
          The GM #3956109 is the correct fan shroud for a 1971 SMALL BLOCK with C-60 application. The same shroud was also used for all 1971 Corvettes with small block and THM-400, with or without C-60. It was used for all 1971 LT-1s (except ZR-1), too.
          The original lower extension for your application was GM #3956118. That part was discontinued in January, 1983 and replaced by GM #331870 which is still available from GM.
          • Ralph A.
            • May 31, 2002
            • 236
            Thanks Joe....Ralph *NM*
            Ralph Adams
            NCRS: 38137 LA: 112
            Slidell, LA 70461
