tires - NCRS Discussion Boards
tires
  • lyndon sharpton
    tires
    how would a 215-60-15 look on the 70-72 cars? would it even work?
  • Dick W.
    • 10483
    Re: tires
    Lyndon, I think that this would probably work. I have used P225-70X15 on 68-72 cars with good results, both driving and cosmetics
    Dick Whittington
      • 15678
      Re: tires
      It would look like a lowrider.
      • Jon H.
        • January 1, 1999
        • 149
        Re: tires
        Your best options for radial tires as close to the correct F70x15 bias ply is a 215/70/15 or a 225/70/15. I have used both with good results. The tires you are trying to use will not look good because there will be a tremendous amount of inner fenderwell showing.
        • Scott Marzahl
          Low rider
          Depends on what you are trying to achieve. I agree with Duke, you will have lots of "open" wheel well showing. If you are planning on lowering the car to use for autocrossing for example, it would look alright.
          • KEN BUTCHER
            245-60x15 or 255-60x15 look cool *NM*
            • Bill E.
              • April 1, 2003
              • 200
              Re: tires
              I have BFG 255/60R15 on my '74 and they look and handle great. Just don't try and put one in your spare tire carrier. Bill
              • Mark #28455
                I'm using 235 60 15 with F41 suspension
                On my cars (1969 and 1970) the 235-60-15 was the largest that wouldn't rub with the F41 suspension.
