How many bolts hold the windshield assy to a '59? I'm going to remove the assy Friday and want to make sure I get them all. I think 12. On each tab there are 2. Then 8 "T" bolts along the frame. It looks like there is a "T" bolt way back in each corner not far from the tabs. Have I got things covered? Thanks again. Pat
C1 windshield assy
Re: C1 windshield assy
I am not sure about a 59 but on my 62 you have described it perfectly.I had all of my nuts off and it would not move.I went under and double check every thing nothing seemed to be holding it in place.
I took a rubber mallet and gave a slight tap up in the door jambs on the courner of the post,It was just enough to brake it loose and it lifted wright off- Top
