C3 Spindels - NCRS Discussion Boards
C3 Spindels
  • Bryan Adams
    C3 Spindels
    Ok I know the controversy, but I have my trailing arms re assembled and checking
    my end play I am .001 on both sides and everything looks good but I want to make
    sure they are correct. I used one shim on each side .115 & .109 Am I only suppose to use one shim? If I go larger .121 then I have way to much end play.
    Is one shim the standard and how free should the spindle spin? I have good drag
    but it does not spin free. I installed new bearings races and new spindles. If I press my bearings back off and start back one again without torqing them I still do not turn free their is still good drag.
    Does this sound correct?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C3 Spindels
    One shim and one collar. There is always drag because of grease and the seal, especially if the seal is new.
    • Joe R.
      • July 31, 1976
      • 4550
      Re: C3 Spindels
      Yes, it sounds good and like a typical rebuilt with close tolerances. Some of the commerical trailing arm builders hold it to 0.0005. Your new bearing should break in just fine and with synthetic or semi-synthetic grease it should last for a lifetime.
      JR
      • Warren L.
        • February 1, 1990
        • 85
        Re: C3 Spindels
        What are you physically doing to that trailing arm to come up with that tolerance, how are you measuring the bearing.
        Warren
