Help with '62 Engine Numbers - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    A seller tells me that his 3782870 (1962 327) engine block has a casting date of "K181" and is stamped "F1111R".
    I interpret these numbers as being cast on November 18, 1961 and machined in Flint on November 11. That didn't happen.
    1. Has the seller read the numbers incorrectly?
    2. Have I interpreted the numbers incorrectly?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Chris, I think you're interpreting...
    ...correctly. I hope the seller needs glasses. These passenger car R stamping blocks are such wonderful doners for RE & RF applications - RC & RD, too.
    • Dennis C.
      • January 1, 1984
      • 2409
      Re: Chris, Of course, my radar always...
      ...beeps when I see IIII assembly stamping date.
      • Dennis C.
        • January 1, 1984
        • 2409
        Re: Especially when IIII is Saturday Nov 61... *NM*
        • Christopher R.
          • March 31, 1975
          • 1599
          What's the deal on "IIII"? Is there something fishy about that stamping?
          • Dennis C.
            • January 1, 1984
            • 2409
            It just makes me suspicious...
            ...Some bozo could make that (date) stamp with a screw driver. Not that some engines weren't assembled on November 11th of some years. But when November 11th falls on a Saturday or Sunday, I usually like to take a deep breath before I start shelling out the frogskins. I want to be personally inspecting "museum quality" broach marks... in addition to the rest of the stamped characters.
            • Christopher R.
              • March 31, 1975
              • 1599
              Re: It just makes me suspicious...
              Oh, I see. I guess if you were going to forge stampings, the "I" would be the easiest. Hmmm, learn something every day.
              I now note that both the "K181" (November 18, 1961) casting date and the "IIII" (November 11) stamping date are both Saturdays. I sometimes work on a Saturday. Did the foundry (Would that be Saginaw?) ever work on a Saturday? Did the Flint engine plant ever work on a Saturday? Did either of them work a Saturday in November of 1961?
              • Dennis C.
                • January 1, 1984
                • 2409
                Of course we still have to deal...
                ...with the issue of stamping a cylinder case before it's been cast. Now, THAT is pretty darn tricky...
                I'm not qualified to answer your question about working Saturdays, but I suspect it may have happened on ocassion. Expert knowledge is out there that would know.
                • Mike M.
                  • May 31, 1974
                  • 8396
                  Re: Of course we still have to deal...
                  they worked an occassional sat(overtime was overtime even in '61). don't think i've ever judged what i thought was an original block cast and machined on a lord's day(unlees it was hit by rev mike). mikie
                    • 11652
                    ...and the fact that, HELLO, November 11 is Veteran's Day???
                    There ain't no chance the union had them working on a national holiday which ALSO was a Saturday.
                    Patrick
                    • Mike E.
                      • February 28, 1975
                      • 5139
                      I've seen several real anomalies on 62's that were undisputed originals. One was assembled the day before it was cast.
                      My best take on this: Should have been stamped FII2IR---someone forgot to change out the I and the 2--that follows what was reasonably often the case--2-5 days between casting and stamping.
                      However, that creates a real bind for the guy who wants to put it in a corvette as correct!!!
                      • Loren Smith
                        Maybe the 1111 was Roman numerials - January 3rd, February 2nd, or March 1st. Seriously, the seller might be dyslexic. Could you talk the seller into emailing you pictures?
                          Pat -
                          Veteran's Day wasn't a Big 3 holiday in those days, and both Saginaw Foundry and Flint V-8 frequently worked on Saturdays; still begs the question of being assembled a week before it was cast
                            • 11652
                            Thanks John.
                            You mean the UAW has added holidays to the mix in the last 42 years? I can't believe that.
                            Patrick
