'66 350HP P.S. PULLEYS AND BELTS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I thought I was going to need the ad-on crankshaft pulley to install power steering (no air), but the 2nd groove on the existing pulley already lines up with the power steering pump pulley. Also, one illustration in the assembly manual shows the belt directly from the crankshaft pulley to the power steering pump pulley, and in the N40 belts and pulleys illustration it shows it routed to the H20 pump pulley as well...which way is it supposed to go?
  • Scott Marzahl
    Re: '66 350HP P.S. PULLEYS AND BELTS
    There has been a fair amount of discussion in the past on this topic, consensus is the manual is wrong, no add on pully crankshaft pulley needed, it doesn't even fit! One belt from the crank to h20 and one for crank, h2o and p/s.
    • Scott Marzahl
      ammendment for that installation
      I believe that the correct C/S, W/P, ALT belt is #3861946. It is 54.00".
      I believe that the correct C/S, W/P, P/S belt is #3861936. It is 45.00".
        • 43236
        Rob-----
        For all practical purposes, there were only 2 p/s pump pullies used for 1963-74 Corvettes with small block (actually, there were 1 or 2 other "rare birds", but I'm not going to get into that issue). One of these pullies is a more-or-less "flat" stamped steel pulley of GM #3770509. When this pulley is used, the add-on, crankshaft pulley is also used. In virtually all cases, the add-on pulley adds a third track to the existing 2 groove crankshaft pulley.
        The other p/s pump pulley used for 63-74 Corvette small block applications is a single groove, cast iron pulley of GM #3834720. This is a "drop-down" style pulley. It is used for applications not using the add-on pulley. In other words, for applications in which the forward groove of the single 2 groove crank pulley is used for p/s pump drive.
        As a GENERAL rule, HP and SHP small blocks use the cast iron, "drop down" pulley with no add-on pulley.
        • Peter L.
          • May 31, 1983
          • 1930
          I hate to be swimming upstream on this "Pulley/Belt" discussion; but there is another explanation in this discussion and that is that UPC 6 A4, Belt Routing, V-8 Engines 327, in the AIM is for the '66 Corvette base 327 engine and NOT the L79 327 Special High Perfomance Engine. This is the same for this section in the '67 AIM. Specifically, none of the UPC 6 A4 belt routing examples show the crank shaft to water pump "captive" belt, P/N 3837810, that has been documented to have been on "original" '66 and '67 L79 engines.
          Anyway, it is not clear to me that the AIM is incorrect; although many '66 and '67 L79 Corvette engines have been made to conform to the illustrations in the AIM because of confusion in the interpretation of the information in the AIM and the Judging Manuals.
          Pete
          • Rob A.
            • December 1, 1991
            • 2126
            Well, I routed the p.s. belt around the crank and H2O pump pulleys. All the auto part stores show it as 45", to include the H2O pulley. It works well, and that's where it will stay, although I don't know what the purpose would be to include the H2O pulley.
            • Peter L.
              • May 31, 1983
              • 1930
              Rob - You can't beat success. The Chevrolet Parts Catalog shows P/N 3861936 for 66 CORVETTE (P/S w/Sp. H/Per.) (327) (exc. C.A.C.). It's a 3/8"-45" belt. My comment was that '66 and '67 L79 327 engines originally had a captive belt that ran from the crank shaft pulley to the H2O pump pulley. Pete
              • Rob A.
                • December 1, 1991
                • 2126
                THANKS FOR THE INFO PETE... *NM*
                • Craig S.
                  • June 30, 1997
                  • 2471
                  Joe - is this true for C60 A/C also? My 67 has N40, C60, and has the 509 pulley, (also A.I.R. but that is another story) .....Craig
                    • 43236
                    Craig-----
                    No, most C-60 small block applications use the '509' p/s pump pulley.
                    • Craig S.
                      • June 30, 1997
                      • 2471
                      Thx Joe!
