STEERING COMPONENTS TORQUE SPECS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Anyone have the torque specs for tie rod end nuts and idler arm nut? Can't find it either the assembly or chassis service manual...
    • 43260
    Re: STEERING COMPONENTS TORQUE SPECS
    Rob----
    The idler arm-to-relay rod nut is torqued to 50 lb/ft + additional torque necessary to align the castle nut with the hole for the cotter pin (not to exceed 60 lb/ft).
    The tie rod end stud nuts are torqued to 35 lb/ft + the additional torque necessary to align the castle nut with the hole for the cotter pin (not to exceed 50 lb/ft).
    • Rob A.
      • December 1, 1991
      • 2126
      THANKS FOR THE QUICK REPLY *NM*
