c1 1960 rearend - NCRS Discussion Boards
c1 1960 rearend
  • Sander B.
    • March 1, 2005
    • 499
    c1 1960 rearend
    hello al is it possible to change the ratio of a 4:11 posi to a 3:73 or 3:55
    ratio or what do i need more than only a ring and pinion ????
    thank You Sander,
  • Roy B.
    • February 1, 1975
    • 7044
    Re: c1 1960 rearend
    That's IT
    • Richard E.
      • November 1, 1976
      • 200
      Re: c1 1960 rearend
      Hey Roy - Assuming his 4:11 is on a series 4 carrier, can Sander plug in a 3:55 set without going to a series 3 carrier? Or is that where the spacer comes in? I plead the fifth...Dick
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Gee, I used to know this stuff... Dick, I want to
        say, you need the spacer going the other way since you are switching to a smaller pinion and need to move the ring gear over toward the pinion. Be nice to get this one right as posting member is a long way from Pep Boys...
        • Roy B.
          • February 1, 1975
          • 7044
          Re: c1 1960 rearend
          that's where the spacer comes in and my brain goes out on the series
          It's the ring gear thickness
          • Richard T.
            • February 1, 1979
            • 858
            Re: c1 1960 rearend
            You can make the change and keep your carrier but you will need a 3 series posi unit along with the ring and pinion. I just made this change on a 62. Rich #2276
            • Sander B.
              • March 1, 2005
              • 499
              Re: c1 1960 rearend
              Rich is this a 3 series ????? (see pic.) saw this one on Ebay
              thanks Sander
                Re: c1 1960 rearend
                Sander -
                The one in the photo (C-30743) is a Series 3, for 3.08 to 3.73 gears; the one for 4.11 gears and up is C-30751.
