C1 PCV Valve - NCRS Discussion Boards
C1 PCV Valve
  • Greg G.
    • June 30, 2004
    • 14
    C1 PCV Valve
    Does anyone know where I can get a PCV valve for a 61? Does anybody make a reproduction valve?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 PCV Valve
    Not that I know of , but check out cars of that year!
    • Christopher R.
      • March 31, 1975
      • 1599
      Re: C1 PCV Valve
      The real PCV valve for that year was a Delco part number something-590-something. You'll never find a real one. But all the vendors sell the Delco service one that's close. Around $9. They're on EBay all the time too.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Re: C1 PCV Valve
        The optional PCV system for late C1's used a servicable screw together style with a hex shape for wrenches. I have managed to find this style (if not the exact part) at swap meets. Maybe a salvage yard with older stuff might prove fruitful. I installed one once that was a F..d part, but after placing the white paper stick-on ID tag, that covered the evidence... Bad Boy, Dennis Oh, by the way, if you find something close, make sure it is designed to flow the correct way. They make them both ways...
        • Mike E.
          • February 28, 1975
          • 5139
          Re: C1 PCV Valve
          The only one I've ever found that had the original GM part number on it (not the 590CV which is actually a replacement/service valve, had a dark (black oxide?) hue to it. I don't believe that the cad/zinc plated finish is correct--I've studied old magazine road tests (done in California) and the appearance is a dark color.
          • Dennis C.
            • January 1, 1984
            • 2409
            Mike... Agree on the "black oxide" plating *NM*
            • Gordon Peterson #4961
              Re: Mike... Agree on the "black oxide" plating
              Okay, not a C1, But my '63 uses a CV590C valve, and there is a clear picture of it in the owner's manual. It is black oxide with a distinct white paper label. I, like most, had the cad plated smooth bodied service replacement of the same part number on my car. Last year on eBay, I questioned every seller about the CV590C they were listing, and sure enough, I finally found one that said his was black. I got it for $9. What I received was the old valve that had been thrown back into the box after the new part had been installed. But after a thorough cleaning, the old part works (and looks) just perfect.
              Pete
