DUST SHIELDS ON A 1963 - NCRS Discussion Boards
  • JOE#34066
    I'm putting dust shields on my 1963. It is very differcult to get these steel staples to close on to the skirt. Is there a special tool? Is there any tricks of the trade? any help would be appreciated.
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: DUST SHIELDS ON A 1963
    A helper comes in handy.
    Stapling Rubber
    • Stephen L.
      • May 31, 1984
      • 3159
      I assume you have drilled the holes thru the new dust shield using the holes in the fender as a guide. (Use a very small drill bit) Insert the new staple thru the dust shield and fender. Use a needle nose pliers to bend the staple leg around the needle nose. This gives you the "curve" in the staple leg. Do one staple at a time... drilling etc., so that you can keep everything straight. As mentioned earlier, you'll probably need a little help
        Geoffrey -
        The part number for the "staple" is actually the number for a sizable spool of 14-ga. or 16-ga. galvanized steel wire that was mounted on a BIG Bostitch air-powered stapler that was hung from an overhead balancer; that sucker would staple anything (same device was used in the car and truck plants that stapled through steel inner fenders).
        • Boyan B.
          • August 31, 1999
          • 189
          I agree with what has already been said. Then hammer and dolley the staples nice and flat to tighten them up. If the body is off, it's a one person job. Body on, get a helper.
          Boyan
