Can anyone direct me to a supplier of correct lower ball joints and rivets for my 69? Thanks
69 lower ball joints
Re: 69 lower ball joints
Periodically, original correct ball joints show up on e EBay. These are the ones with the non-thread extension on the pin and the boot with a metal band around it to keep it on. I recall recently seeing and aftermarket joint with these features but I don't recall where. Check with the Corvette vendors. Rivets are available from the vendors too.- Top
Greg,
The link below might be of interest. I have NO idea if the claims made here are accurate, but someone else may know how "correct" they really are. I'm sure the seller has more if these go before you find out if they are what you need.
tc
eBay ball joints- Top
tracy-----
These are reproductions currently offered by America's Finest Corvette of Ramona, CA. I've not seen them "in-the-flesh", but I have looked at some fairly close-up pictures of them. I'd say that they're about 90-95% correct in terms of configuration/appearance. I think that they would be detectable on the car, but only if the judge was VERY experienced and checked them VERY closely (not so easy to do installed on the car). I believe that the seller here is the above-referenced.In Appreciation of John Hinckley- Top
Rough and dirty, landed at your door, the two will cost $700 in canadian funds,IF you can convince the vendor to ship to Canada.
You still need another two which could potentially drive the cost up to $1400,
How badly do you want NOS ball joints?- Top
