58 replacement radiator - NCRS Discussion Boards
  • Ken Susnjara
    I need a radiator for my 58 project and am considering the DeWitts Direct Fit aluminum in black for better cooling. I also want the car judged. What will likely happen? Any advice is appreciated. Thanks.
  • Jerry C.
    • November 1, 1995
    • 741
    Re: 58 replacement radiator
    If you put the brass ID tag on it should be no deduct.
    • Kevin T.
      • August 31, 2002
      • 84
      I had an aluminum radiator from DeWitt's installed in my 59. What is a good source for the brass radiator ID tag? DeWitt's, Paragon, etc.? What is the recommended type of application? Does it need to be soldered on? Thanks. - Kevin
