Hello all
Just went to have a wheel alignment done and discovered my rr trailing arm is slightly bent. Now the question is did they have a vertical bead of weld mid length in the arm when they were new. It seems both mine have this weld which seems to suit no purpose. On finding out that mine was bent I was wondering if someone had welded a plate on there for straightening/pulling purposes and never ground off the weld after removing the plate. Can any other 63 owners tell me if they also show this weld?
Thanks in advance
Larry Boden
Thanks in advance
Larry Boden
