C2 Heater fuse - NCRS Discussion Boards
C2 Heater fuse
+ More Options
Posts
  • Mike M.
    • August 31, 2006
    • 23
    C2 Heater fuse
    Anyone know why my heater fan works fine with the engine off, but when it's running and I turn the heater on it blows the 10amp fuse in the fuse box. I used a 20 amp fuse and it will work with the engine running, but my instrument lights appear noticably dimmer when my lights are on. thanks
  • Brian M.
    • February 1, 1997
    • 1840
    Re: C2 Heater fuse
    What year are you working with? My 67 owners manual calls for a 25 amp fuse with a 30 amp. for high blower speed (in Line)
    • Dixon Green
      • Mike M.
        • August 31, 2006
        • 23
        Re: C2 Heater fuse
        It's a 64. Calls for a 10 amp fuse since I don't have air conditioning. thanks
        • Wayne W.
          • April 30, 1982
          • 3605
          Re: C2 Heater fuse
          It would help to get a little more information. You say it runs with the engine off. Does that mean with the key in the off position or in the run position but without the engine running. My guess is that you have the ground wire to the blower motor hooked up to the hot wire at the starter. How about the wipers? What do they act like?
          • Mike M.
            • August 31, 2006
            • 23
            Re: C2 Heater fuse
            I was blowing the fuse before I replaced the harness. I put a new resistor on and now it seems to work fine. Thanks for the help though.
