C3 Spare Tire Lock - NCRS Discussion Boards
C3 Spare Tire Lock
  • Bill E.
    • April 1, 2003
    • 200
    C3 Spare Tire Lock
    I'm thinking of buying a lock for the spare on my '74. Does the spare tire lock just keep the bolt from being turned or does it also prevent the bolt from slipping out of the lower tub? Thanks, Bill
  • James Keddie
    Re: C3 Spare Tire Lock
    Hi Bill, I have the original spare tire lock on my '70 and it just prevents the bolt holding the spare tire tub up from being loosened. If the bolt is tight enough the tub will not drop. Good luck. Jim
      When you shop for a spare tire lock remember, in the era of your car all locks were keyway encoded (A/B, C/D, Etc.) and the 'test' of a correct Shark lock is that it will accept the correct keyway coded key blank and 'reject' other coded keyways (won't insert more than 3/4-way into the lock cylinder). Some of the locks out there are potporri coded (random draw from what the supplier has on the shelf) and others are 'universally' coded (will accept any key).
      So, if you're out to buy a 'correct' spare tire lock for your '74, you'd like it to match the existing 'K' keyway of your original glove box key....
