Emergency Brake Anchor Bolt - NCRS Discussion Boards
  • Elm Zobens
    HELP!
    I am in the process of assembling my training arms on my 69' coupe and I can't press the spindles back into the bearings unless I know the torque for the emergency brake anchor bolt for the rear shoes.
    I have all the factory shop manuals for 69 thru 74 Corvettes and not one of them seems to indicate a torque setting for this bolt. I can find the torque for the backing plate/spindle housing bolts (30 ft/lbs) but nothing the the large anchor bolt at the top of the backing plate. Either I'm just being stupid and can't find it or GM failed to supply this little piece of information.
    Can anyone help?
    Thanks!
    Elm
    • 43221
    Re: Emergency Brake Anchor Bolt
    Elm-----
    The bolt to which you refer is one of the "mystery" bolts on a 63-82 Corvette. I don't think that you'll find the torque specifications in ANY model year Factory Service Manual. However, the bolt in question is a 1/2"-20 bolt of SAE Grade 8 specification. With lubricated threads, the "standard" torque spec for this size bolt would be 90-100 lb/ft. I would torque the bolt at 90 lb/ft, on the low side of the range, since this bolt is threaded into the relatively thin, nodular iron rear caliper bracket.
