I am in the process of checking the adjustments to my steering gear (64 p/s), and am pussled by the description in the shop manual.
In the shop manual "to adjust worm bearings, loosen worm bearing adjuster lock nut and turn worm bearing adjuster until there is no percoptible end play in worm. I can't see any "adjuster"... once I loosen the large lock nut at the back of the box what do I turn ?...
In the next step (after adjusting the worm) the manual references a "mark" on the top of the wormshaft just below the coupling clamp. I can't find any such "mark" (do you need to remove the coupler to see this?...anyone have a picture?...
