89 third brake light - NCRS Discussion Boards
  • Steve L.
    • May 31, 2001
    • 34
    My 1989 vette's third brake light does not come on. The standard brake lights work fine. There is no voltage at the third brake light. Is there a relay or fuse in the circuit that I need to check to get the brake light working again?
  • Mike S.
    • March 1, 2005
    • 125
    Re: 89 third brake light
    steve the third brake light runs off the same fuse as brake lights 20amp.the power wire comes off the brake switch .its a 20ga. wire light blue . also be sure to check your gound wire black wire.if you have a fax i will send you wiring diagram.MIKE
    • Steve L.
      • May 31, 2001
      • 34
      Thanks for your help Mike. The problem turned out to be a bad brake light switch. It was difficult to understand because it partially worked on the main brake lights. The switch has duty on two circuits though and I guess one set of contacts was not making.
